DERICKS
I need your advice or experiences with stall speed on a combination like mine. The converter flashes 3600 at best on a hot day and the car feels a little lazy to me. I was told by Sean at Dynamic that he could get it to flash 4200-4400 after reworking it. Is that enough for my combo or do I need to go to an 8 inch converter at 4500+?? Thanks
Car 1973 Duster
Weight 3250 with driver
Gear ratio 4.30
Tire diameter 28
RPM through trap 6100
1.63 sixty foot best ever usually 1.70's
MPH through traps 111.87
ET 11.99
Engine CID 346
Head Type factory 308 casting
Valve size 2.02/1.60
Head Work none other than 2.02 intake valve
Cam Manufacturer Mopar performance
Cam specs at 50 .248
Carb type and size Holley HP 750
PV Rating 3.5/none
Jet sizes 78/82
Plug number and brand champion RN9YC
Intake Manifold Type Edelbrock Torker II
Piston Make TRW replacements
Compression Ratio 10.5
Trans type 904
Trans Mods T/A reverse manual valve body
Convertor type Dynamic 9 1/2
Convertor stall 3600
Trans Brake none
Drive shaft stock or aftermarket dynatech
Initial timing 36
Total timing 36
Total advance at what RPM locked out
Rear end type 8 3/4 with back brace, spool, mark williams caps, rifle drilled mark williams axles
Car 1973 Duster
Gear ratio 4.30
Tire diameter 28
ET 11.99
Engine CID 346
PV Rating 3.5/none
Jet sizes 78/82
Trans type 904
Trans Brake none
Initial timing 36
Total timing 36
