There are 4-5 stamping letters they use for installing pistons.Each of the letters is a code for a piston that will have the final piston to wall clearance in ten thousands of a inch.For every bore after checking the bore a number is given and a letter is stamped to the oil pan rail to show the installers the proper piston assembly to install.If we use a 440 bore of 4.320,and the bore is measured at 4.3202,you would get a C,for two tenths over sized,and the matching piston is just a slight bit bigger at the piston skirt,getting the correct piston to wall clearance.This system allows for under and over bore cylinders,as the rod assemblies are in a large 5 foot square bin and thousands are in there,and there is a bin for each letter.mrmopartech
