I thought I was gonna have my car running this weekend but starter is dead.
I have a 74 duster with a 360 and tti headers. I have seen the listed starters on the tti site but I would like to know what one you guys recommend before I spend the money.
Also I have a 904 trans but they don't say anything about it on the tti site when they talk about starters.
TTI FOOTNOTE # 10
Starters: Required with the following applications combinations...
Application
Combination >>>
Flywheel
10.5” clutch
Transmission
Standard / 727
Ring Gear Teeth
130-tooth
Starters required
Chrysler part #’s R53005984, 56027702AC
Mopar Performance part #’s P5249644AB, P5007860, P4286522
PowerMaster Clockable Starter - part # 9523
Application
Combination >>>
Exception: 62-65 Hemi's
Flywheel
11” clutch
Transmission
Standard
Ring Gear Teeth
143-tooth
Starter Required
RobbMc Perf. Mini Starter - Part #2005
Small Block Note: Lightweight Mini Starters can easily be changed without removing the header.
What starters are you guys/gals running?
TTI FOOTNOTE # 10
Application
Combination >>>
Flywheel
10.5” clutch
Transmission
Standard / 727
Ring Gear Teeth
130-tooth
Starters required
Application
Combination >>>
Flywheel
11” clutch
Transmission
Standard
Ring Gear Teeth
143-tooth
Starter Required
