starter issues
dirty white boy
50 yr old Juvenal delinquent
stoneville n.c.
need a lil mopar wisdom,..just tryed to crank my /6 883od 79 d100 and when turning key all i get is starter solenoid clicking, so i crossed post on starter and it spun over fine but no fire, pulled plug wire and stuck screw driver in it and held it near alt bracket and spun it again and no fire to plugs,...i need a new starter relay dont i????
When you bypass the starter relay the way you did, unless the key is in the run position it will not fire.
Try it again with key in run.
But yes with the limited testing the starter relay is very suspect.
yes,..key was on!! getting very weak spark to plugs... lights work as well as everything else!
The key uses 2 separate circuits during starting.
IGN 2 bypasses the ballast resistor so during the drain of cranking there is more voltage available for spark.
You can duplicate that by running a jumper from battery plus to the coil side of the ballast resistor. Don't leave it on very long otmr you can cook the coil.
EDIT LOL I was typing..................
May or may not be the starter relay, "how it works."
Notice you have two flag/ push on terminals on the relay. These are the relay coil. The huge stud gets power from the battery, serves as a junction point for other components, and is one of the relay contacts. The other contact is the "square" terminal which feeds down to the solenoid.
If you can get the starter to crank when you jumper the two bare large terminals on the relay, the relay is getting power to the contact and the starter sol wire is good.
One of the flag terminals feeding the relay coil gets power when you twist the key to start, but it needs a ground. On automatics, the remaining "flag" terminal has a wire going down to the center contact on the neutral switch on the automatic to ground. On a stick that wire goes to the clutch pedal mounted switch
So take a meter/ test light and make sure the relay is getting power from the key in "start" and make sure the neutral switch is grounding. You can remove that wire, and ground that flag terminal temporarily to test it
HOW THE KEY works
Normally when you twist the key to start, the key also kills the "run" voltage to the ignition. That power is supplied by (older models) from a different contact on the ignition switch, feeding power in start to the coil + side of the ballast. On newer rigs, the start relay has a FIFTH terminal and it does that job, instead.
As said above, when you jumper the starter, that circuit does not engage, so you get a weak spark. Most vehicles, tho, in good shape, and tuned up will start that way
OP stated the relay was clicking. That indicates the NSS and Key is working properly.
I've had to replace the cables themselves on many of my Mopar vehicles cover the years. Cut the insulation off and they're all a green powder... And DON'T use those Mickey mouse cable ends where you strip the end and use a 2 bolt strap to hold the cable ends to the cable. About as useless as a Scotchlok
