64 /6 auto
Starter does not crank when key is in start position (no click – no nothing). Cranks fine and starts when jumping ground post to hot post on relay. So I did the following tests:
· Battery a little low – voltage between batt terminals is 11.5
· G (ground) post – brown wire to NSS – continuity to ground – voltage between post and POS battery post 11.5 – looks good
· Ign post – yellow wire from ignition switch – 11.5 volts when key turned to start position – looks good
· Starter ground post (screw on) – brown wire in pigtail to starter ground bolt – continuity to ground - voltage between post and POS battery post 11.5 – looks good
This was last weekend, so I thought maybe the starter relay was bad. Ordered one online which came yesterday. Installed it this morning, got same results. Redid the tests above – got same results. Wiring all looks in good shape. So what am I missing?
