I am in the process of installing an aftermarket wiring harness kit from Ron Francis and I'm not quite sure if how I have the starter relay wired up is okay?
Briefly, the R.F. instructions would have me sending a total of 5 wires (including battery + cable) to the starter battery post, which I didn't feel was the most effective and safest option (since no fusing of any of the wires were mentioned).
What I did instead was run 3 MIDI fuses on three of the lines (50 amps for battery feed coming out of fuse box, 50 amps for ignition switch power solenoid, and 80 amps for alternator wire). These three lines were then connected to the "BAT" post on the starter relay instead of starter post.
The 69 wiring diagram has the main battery positive cable (2-4 gauge wire) going directly to the starter battery post (obvious), but also has a 10 gauge short wire that goes from the battery positive post to the starter relay "BAT" post.
My set up would then have 4 wires running from the starter relay "BAT" post as described above. (I already know how the other wires hook up on starter relay so that is not an issue. Also, I do know that having 4 wires on one stud can develop some resistance, so I will consider a power stud option, if the need arises)
My major question/dilemma is in the R.F. wiring instructions they have a "starter relay wire" that would run from the starter relay "BAT" post to the starter battery post, but no wiring coming off the battery positive post to the starter relay post, like in the original 69 wiring diagram.
Do I still need to run a wire from the starter relay "BAT" post to the starter solenoid battery post or can I just run the short 10 gauge wire (like factory) from battery positive post to starter relay "BAT" post, as I have outlined above? If it does matter, which wiring option would be the best way to go (please explain in detail) or do I need to run both? (if so, why? I would really hate to have 5 wires going to relay "bat")
I am running aftermarket electronic gauges and with the new wiring harness, the bulkhead/ammeter wiring is no longer used.
Any help would be greatly appreciated!
