Actually... get one from a 2005-2008 Dodge Ram with a 5.7 and a MANUAL transmission, as the automatic one is different.
2005 DODGE RAM 1500 PICKUP 5.7L V8 Starter Motor | RockAuto
That’s the wrong one. Get 1 for a 1996 full size dodge truck with a 5.2 or 5.9. What is that for? Kim
Would be interesting to see who’s running 727 or 904....
Mine is a 904.
Think i will go with a msd dyna force starter now
Mine is a 904.
Need to find a starter. Engine has 14: 1 compression. What are the best options. What are you guys using?
I have one on my 904 transmission. My 96 dakota has a 360 magnum engine and a 904 transmission. The starter cam off a 95 dakota sport with a 5.2 magnum and automatic transmission. But I don't remember what size transmission it hadWould be interesting to see who’s running 727 or 904....
That would be a starter from a magnum engine.... Mr 74Scamp was trying to use a Geniii hemi starter that some have used with success apparently. I’m just wondering if those guys were using 727s.I have one on my 904 transmission. My 96 dakota has a 360 magnum engine and a 904 transmission. The starter cam off a 95 dakota sport with a 5.2 magnum and automatic transmission. But I don't remember what size transmission it had
Oh sorry I missed that part.. are you thinking about trying one?That would be a starter from a magnum engine.... Mr 74Scamp was trying to use a Geniii hemi starter that some have used with success apparently. I’m just wondering if those guys were using 727s.
For the last 20 years all I've ran is a starter for a 93 5.2 Dakota and see no reason to change.
Exactly, so anybody used the 2005 dodge ram manual trans starter with success?
I bought it because it is stonger (1.7kw) than the normal mini starters, as they spin my engine barely when its cold and not at all when its hot.
Tried a lot to prevent heat soak but have not found a solution yet so i just try a stronger starter. My compression is actuall only about 10 to 1
Oh sorry I understand now. I think Rob MC makes or made a clock able mopar mini starter. But I am sure it's lots more money. I might buy one of the hemi starters and see if it will fit my engine set upThat would be a starter from a magnum engine.... Mr 74Scamp was trying to use a Geniii hemi starter that some have used with success apparently. I’m just wondering if those guys were using 727s.
