Starting my Early-A Conversion to disc
@MidnightSwinger I ran my master lines to the outside of the clutch pedal linkage. Took a little coaxing. Not sure if correct. It made it easier to get the torque shaft in place. Works just fine and clears well.
Which line from the new tandem master goes to the rear brakes? Or does it matter?
The hole to the rear of the block. goes to the rear brakes.
Ya but which port on the master? Probably doesn't matter on my 4 wheel drum master .
