Vs29H1B
This evening I hopped into my 1971 Duster 340, gave the gas pedal a couple of pumps, and turned the ignition key to the start position.
The car cranked a couple of revolutions, but did not start. This is, BTW, quite typical of this car, after sitting for a couple days. Usually just pumping the gas pedal a couple more times, then turning the ignition key to the Start position starts the car. The car still has the points distributor installed and the Thermoquad.
On the second start attempt tonight, when I turn the ignition key to the Start position, all I get is a slight diming of the Red BRAKE lamp that illuminates on the dash.
No clicking, no starter engagement, no noise, no nothing, just the diming of the Red BRAKE lamp on the dash.
The battery seems to be strong, so where do I start looking for the problem, and what procedure should be used to test all parts of the starting circuit.
I am thinking I may have either a bad starter relay on the inner fender, a bad starter, or perhaps the cable to the relay or starter is bad.
How do I eliminate each component in the starting circuit, and in what sequence, to find the bad part?
Any help is appreciated.
