I looked at your photos you posted and it looks like you have the sport steering wheel. This wheel is much rarer than the standard wheel. My suggestion would be to remove the cover, fix whatever cracks that the wheel may have in it and run that one.
If you are looking for a more comfortable wheel, Grant makes a wheel that is very similar to what your wheel looks like and has a nice comfortable rubber rim. The diameter is also slightly smaller which will feel much better but won't block the gauges like some of the smaller wheels do. Be careful about the woodgraiin wheel diameter. You may find yourself having to look around the rim to see what speed you are going.
