fenderman33
What's the difference between a power steering box from a 73 Duster and the one for a 72 Duster? Difference pitman arm? Is there a way to make them interchange?
Thanks,
Jon
Thanks,
Jon
the difference in the boxes is the spline size where the pitman arm attaches.
they changed in 73....they are largers...
now the second part....in 73 the A bodies got the larger brakes from the E/B bodies....they also changed the drag link.....
the new drag link in 73 takes the pittman arm and idler arm in the opposite direction then the 73 and older...
So if you have access to a manual steering box and steering column from a 1972 duster, it will fit in a 1973 duster.
hope this helps,
Bob
