The coupler is held on the steering gear shaft with a roll pin. (see roll pin hole on the far left) I had to remove the column from the car to remove the steering shaft to shoe pin. (you can't get the bushing up the shaft with the pin in place) I think it would have been easier to remove the shaft from the column, replace the bushing and re assemble. That cross pin was in there tight. Hopefully someone will chime in that has done one on your model. tmm
