steering column dissembly question
HemiDenny
HDK Suspension
NW Ohio
I'm working on a '67 automatic steering column and cannot figure out how to detach the outer column from the steering head.I have a '68 tech manual that shows an allen head screw behind the shift lever (once removed) however the '67 model is different or I'm missing it.
Also where can I purchase the tab for the reverse light that is non-reusable once removed? It is located near the floor column support
got it apart ....thanks for all your help....
still lookin' for tab for reverse switch
