4DrSwingr
Member
Hey everyone I’m just curious if it’s possible to drop my steering column so that I can pull the gauge cluster on 74 Dart. Cheers and thanks in advance for any help.
Yes.Hey everyone I’m just curious if it’s possible to drop my steering column so that I can pull the gauge cluster on 74 Dart. Cheers and thanks in advance for any help.
You also need to disconnect the column from the floor/firewall and if you align the coupler just right you get more angle.Directly under the cluster you will see three bolts with a star pattern washer. See diagram
