unknownsnake Well-Known Member Joined Oct 18, 2009 Messages 1,866 Reaction score 50 Location Mason, MI Feb 26, 2012 #1 so i went to put my column back in and it being a pain... Is there something I should know or do?ops:rotest:
70Duster440 Well-Known Member Joined Jan 8, 2006 Messages 2,692 Reaction score 435 Location Washington Feb 26, 2012 #2 What kind of problem are you having?
wjajr Well-Known Member Joined Dec 12, 2009 Messages 884 Reaction score 135 Location Maine Feb 26, 2012 #3 Are you having a problem with the coupler seal, adjusting length of column, bolting it in, or what?
67Dart273 Well-Known Member Joined Oct 14, 2010 Messages 60,069 Reaction score 33,345 Location Idaho Feb 26, 2012 #4 1 Throw it in the car:glasses7: 2 Tie it part way up into the dash with wire, tie wraps string, duck tape, or have your girl friend hold it there=P~ 3 Get under the hood and line up the splines, slide it on the couplerrofilel: 4 Go back into the car and bolt up the column support under the dash, loose:tongue10: 5 Start the bolts into the floor flangeirate: 6 Make sure everything is OK, drive the pin through the shaft coupler, and tighten all the bolts.:-\" 7 Now that you've tried it your way, download and read the factory shop manual:-| http://www.forabodiesonly.com/mopar/showthread.php?t=132309&highlight=manual,+download
unknownsnake Well-Known Member Joined Oct 18, 2009 Messages 1,866 Reaction score 50 Location Mason, MI Feb 26, 2012 #5 coupler wont line up to gear box
67Dart273 Well-Known Member Joined Oct 14, 2010 Messages 60,069 Reaction score 33,345 Location Idaho Feb 26, 2012 #6 It only goes one way "it's keyed"
R RedFish Well-Known Member Joined Sep 5, 2007 Messages 25,850 Reaction score 5,348 Feb 27, 2012 #7 With the steering gear centered the master spline ill be on top where it can be seen. The coupler has a tiny notch cut into the edhe to indicate where its master spline is since it can't be seen.
unknownsnake Well-Known Member Joined Oct 18, 2009 Messages 1,866 Reaction score 50 Location Mason, MI Feb 27, 2012 #8 ok i will have to check it out again thanks
