steering column lower bushing (bearing)
67dodgedartconv
pass christian, mississippi
I have a 69 barracuda power steering column that I need to order the lower bushing or bearing for - the white plastic piece with the metal bearing in it. The column is at a shop a couple of hours away from me. I need to know if it was the bearing that took 3 bolts or 2 bolts. Is it as simple as looking for either 2 bolt holes or 3 holes in the bottom of the outer column? Thanks for any help.
Most folks don't use those anymore because they for a far better replacement for less money.
SER205-16, SER205-16, ER-16 1" Bore Insert Bearing with Snap Ring 1" x 52mm | eBay
