73 Plymouth Duster
I have a power steering 318 73 duster with a Grant steering wheel. The problem I am having is the steering wheel (and obviously the shaft it's bolted to) will move in and out slightly. It will stop when you try to pull on it and leaves like 1/8th in between steering wheel back plate and column. But it will work it's way down every 5 min to where it will settle on the column and rub, which makes for terrible steering and dragging.
How to I keep it locked in the "out 1/8th inch" position so it won't rub? Did I miss a spacer or something when I put on the steering wheel?
