if getting rid of stock mopar connection at the steering gear box, which u joint is used to replace it? tia
pricey parts, aren't they. thanks. the last borgeson ones aren't too bad.
The stock manual steering is a 3/4"-36 spline and would use a Borgeson part #013464, power steering is a 5/8-36 spline and would use a Borgeson part #0125164if getting rid of stock mopar connection at the steering gear box, which u joint is used to replace it? tia
Was that originally a power steering shaft that you converted to manual the u joint helped you achieve the longer length need when switching over?3/4" Round X 3/4-36 Black Powder Coated IMCA Racing Steering U Joint Coupler NEW | eBay
This is what I’m using, for manual steering.
Me either and there’s some shitty roads on my way to work lolI personally did not notice any extra vibration when switching from a stock mopar steering adapter to a borgeson one.
