GSXcite
I did not have a puller that would keep the cover in place, but I used my drill press to apply pressure while I bent the tabs over. Worked great.I had the spring clip on mine for a while, but its also a PIA when working on it.
This Spring when I had the steering column out anyway, I installed a replacement cover and punched it down after bending the tabs.
There's guidance about this in some threads - either here or moparts IIRC.
I used a puller as a third hand to keep the cover in position
