Steering coupler's are different!
LovetheA's
Fairfield, CT
I'm putting this out there hoping for some help from the community. In the process of replacing and rebuilding my 67 dart manual steering column and coupler. I ordered what I thought was an exact replacement for my car. Well when I started to put the new coupler in there is a distinct difference between my old one and my new one. The new coupler has a small hole at the top where the lid and gasket clips on. I'm assuming I need to purchase or find a dowel or roll pin to put in there to fill hole? Is this pin to hold in the parts inside the coupler? Can I just fill the hole or if I have to buy a new pin what is it and where can I get it? See the attached photo to reference. Any help much appreciated.
Carl
Put a roll pin in there. It's not necessary, but one thing that I did on both of my sons' cars was to drill/tap a hole in that area and put a screw in. I did this before I knew the factory had solved the problem in later years. It prevents the coupler from coming apart when removing the column.
Jim
How long should the roll pin be? I found one at the local hardware store by me and it would fit in there nice and tight if I lightly knocked it in. I'm just wondering if it might need to be cut down in length. The one I have is approx 3/4 inch.
That little pin is closer to a 1/4 long, maybe only 3/16, Didn't enter very far.
Put it together and stick a small screwdriver in the hole. You'll then know how long it should be.
