72ScampTramp
Scamp Tramp
Im putting the front end of my Scamp back together. All new front suspension and steering. Any tips? Is there a good way to get the geometry close eye balling it? No weight on the suspension its on stands for now.
Well......not really. The upper arm adjustments affects both castor and camber. You could set toe pretty easy enough to herd it down to the alignment shop.
You can Google front end alignment, and there's all sorts of caster / camber gauges if you want to learn it yourself.
Some articles:
http://www.carcraft.com/howto/48938/index.html
http://www.allpar.com/fix/alignment.html
http://www.hotrod.com/techarticles/chassis/hrdp_0411_wheel_alignment_guide/index.html
No, the bolt should tighten it up to where it takes some effort to turn, and there should be NO up/ down play. Either the K mounting is bent, you are missing some parts, or it's the wrong idler.
Only picture I have is the 67 which shows a single--ended mounting scheme
Here's another thread on the subject
http://www.forabodiesonly.com/mopar/showthread.php?t=79013
(Sure wish someone would put service manuals online)
Josh this is from my 66 parts book it should give ya an idea where **** goesI havent tightened it down yet. I guess I was thinking it should fit tighter then that to start. Ill tighten it down and see what I get thanks.
....Hey Rob.........good to see u added ur pic........nice toothy grin.....jk........kim........
That picture is the same as my 67 service manual shows, and it's not correct in this case---his idler has a through hole and uses a bolt and nut. the K member "captures" both ends.
