player1up
Last night I decided to start taking care of the vibration noises inside the car. One was coming from the steering column ( it was rubbing on the plastic cover plate that screws to the dash). So I loosened the 4 bolts that hold the steering column sections together and pulled it out about 1/8-1/4 of an inch and tightened it back down... now this morning on the way to work the steering got tighter and now when I move the wheel back and forth, the shift lever moves a little..
What did I do wrong? I want to fix this before I drive it too much further. It's tight enough so that it wont let the steering wheel return to center after I let go.
