purplescamper
where would i get a step by step lower control arm rebuild . by pics ?
thanks
thanks
There is a video on youtube of closing the spread apart arms and welding on something to reinforce. I say "something" because fancy retail vendor plates aren't really needed. A couple of small pieces of flat bar will do. Since there are options in lower arm bushing materials, The instructions will vary. Determine what bushing you'll use and have those in hand first. Otherwise you might cut out an outer shell that was needed.
I dont think theres anything to rebuild..other than changing the bushings. I just removed it, had them sandblasted and I spray bombed them with plastic-kote cast aluminum paint.
Could be a lot to do beyond the bushing, in my opinion...
