bayyum
kay, im buying 2 18" subs for the five-one-0 and i would like to know, what kind of amp do i need? im looking a 5500 watt mono channel amp. or 4000 4 channel thats bridgable. im open to anything really, what do i need?
it says 8 ohms, and 2000 watts. and i may go 4-channel amp that'll work with it, what size should i get?
its going in a 91 f150, and i dont play my music loud at all. and will not be using near the max of bass. ill probably use very little considering i like country..
Country music sounds good on sub systems IF the amps are adjusted correctly. I have a friend who loves country music. He asked what my system sound like with country. I told him to hop in a take a listen. He liked it very much. I like to listen to Hank Jr myself on the aftermarket stereo system.
The number one mistake most of the time is the subs aren't adjusted correctly. I even have a hard time fine tuning the amps because I listen so many different types of music. This is when the bass boost control comes in handy and also the head unit equalizer.
the box or encloser the sub (s) are in makes a big difference to...
