Stick Rods to measure Jet sizes.
George Jets
1967 Dart 2 Door
Farmington MN
Made up a couple of aluminum "Stick Rods" to measure the primary jet size on the Edelbrock Carbs.
Can remove one metering rod from the top of the carb and stick the primary jet without having to take the top of the carb off to see what size they are. (they are hard to read what size they are even with a magnifying glass when they are out).
Then a person can make a decision on metering rod changes, and or spring changes based on the jet size. Helps to decide if a person needs to change the jet size up or down too.
3 test sizes:
.095
.098
.101 ths.
So you have your primary jets, your secondary jets ...............................................................and your George Jets!!!:rofl:
