Stihl Carburetor Parts
No, I can figure it out just fine. What I cant figure out is your criticism, which has nothing to do with the OP. Keep it constructive to the topic on hand. Stupid and degrading comments get you a nice vacation, consider this your warning.
Didn't mean to piss anyone one off.
Just drives me crazy when smart people use off brand none OE parts.
Lesson leaned.
Lesson leaned.
I get where you're coming from, but it's an old blower that I'm not even sure how much longer it will last. It's been used quite a bit, and if this $15 carb doesn't fix it and I've got to get an OE, it's all good. Hell, if this carb is junk I may take the gaskets out of it and use them on the other carb.
Just wanted to give you guys my results. Tore the blower back down, took off the old carb and swapped it for the new one. Got it all back together and I've ran it probably an hour or so today with no issues. I thought it was idling kinda high so I tried to lower the idle only to have it bog down and die off idle. So I reset my adjustments and it runs great. For less than 20 bucks it runs great again. Thanks all for your suggestions and advice!
