Wedgexx
Active Member
Good luck!
Why is there so much stupidness on this thread? TIMING FIRST. Without that, you will be chasing your tail.
Pray tell what was causing the rich at idle problem?
put the -10 back in, the hole is too big for the -8, run -10 to your pumpGot the cell and new line all ran, car runs great, but i have another problem, the fuel cell i got had a -10 bulkhead and i put a -8 in it with the plastic washers, and it is leaking, is there a way to fix that?
