iran
Hi ,
i have a stock 318 engine that it has 2 barrel carb , i wanna know that is it alright to change the stock cam with this:
Basic Operating RPM Range: 1,800-5,500
Intake Duration at 050 inch Lift: 218
Exhaust Duration at 050 inch Lift: 228
Duration at 050 inch Lift: 218 int./228 exh.
Advertised Intake Duration: 276
Advertised Exhaust Duration: 288
Advertised Duration: 276 int./288 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.441 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.441 in.
Valve Lift with Factory Rocker Arm Ratio: 0.441 int./0.441 exh.
Lobe Separation (degrees): 114
is it alright to put it on without changing valve springs? i know it's needed to change valve spring but i don't have it , and it's enough for me if it only works better than stock cam . and if it's okay then how much hp do you think it can add?
