Duane
My 340 w2 motor with my newly ported heads is headed for the high ten second bracket et.
I am contemplating a change of my stock 69 340 rods with arp bolts to an aftermarket 4340 rod for durability concerns. ( eagle H beam is my first choice )
Does anyone think my stock rods with the arp bolts are adequate or do you agree with my contemplated rod change. The motor has already run 11.20 in the quarter in a 1968 dart at about 3100 pounds and should run faster with my ported heads.
This is not a stroker motor and I estimate it will need to rev to 7400 trap rpm.
What are your opinions please. I have been advised by some that the stock rods will not cut it and others have said the steel from stock rods of this year had superior steel to newer aftermarket rods. The stock rods had been re bushed and resized with arp 2000 bolts.
Thanks
Duane
Thanks
Duane
