Slantsix64
Hey guys wondering whats the max lift on a stock magnum head with 1.6 rockers trying to run up to .533 lift on those puppies heres the cam info
Lift: .507 / .533, Duration @ .050: 221 / 225, Centerline: 108, Mild idle, Street performance, Big low end torque, Should have 9.0:1+ compression & 1800+ stall converter.
5.2L - 5.9L Magnum
Camshaft Type:
Hydraulic Roller
Basic RPM Range: 1200 to 5700
Valve Lift Intake:.507
Valve Lift Exhaust:.533
Duration Intake:274
Duration Exhaust:278
Duration at 050 Intake: 221
Duration at 050 Exhaust:225
Lobe Separation:112
Intake Centerline:108
5.2L - 5.9L Magnum
Camshaft Type:
Hydraulic Roller
Duration Intake:274
Lobe Separation:112
