AJ/FormS
68 Formua-S fastback clone 367/A833/GVod/3.55s
- Joined
- Jan 19, 2014
- Messages
- 25,021
- Reaction score
- 12,366
The shunt is part of the ammeter gauge. You can bridge the terminals on the back, or you can move one ring terminal to the other side. Your gauge will no longer work.
I suppose for testing purposes, you could wire in a 12ga jumper, somewhere else, going around the gauge; on account of it being a real PITA to pull the dash-console out. You would need to go from the battery to the ballast resistor feed. This will energize everything on the Run circuit, going back to the sw. Everything will work like normal, except the car will not shut off until the jumper is un-clipped. Turn on everything electrical including the 4-ways, and record the charge voltage on the battery with the engine idling. Then shut everything off including removing the jumper. And test the battery REST voltage, which should be no lower than perhaps 1 to 1.5 volts less than the recorded charge voltage. This assumes the battery was fully charged at the start of the test.
If this test shows everything is in order, NOW it's time to pull the cluster (battery disconnected), and bypass or replace the ammeter. If you decide to bypass it, you will probably want to install a voltmeter somewhere in the cab,permanently.
