motorpirate
serial mopar owner
1320÷93=14.19...That’s enough MPH to be in the 14’s.
must be a bad 60 ft. 93 mph should be 14-something. But I agree, I would think the car would run better than that 93 mph.Well got to try my swap out a the track. 69 Dart ,1995 5.9 obd1 from a ram. Completely stock other than 340 manifolds and dual exhaust,833 4spd, 3.23 gears, skinny 14 radials. Best I could do was 15.68 et @93mph. Thought it would do better, car feels faster than that
Usually that math works best for bracket cars. In other words, cars that are built and meant to 60 ft., etc. You know, 4.30 gears, slicks, if automatic 8" converter. Usually have to add .3-4 tenths for street cars.1320÷93=14.19...
That was my thought as wellThat’s enough MPH to be in the 14’s.
It gives at least a "rough" idea.Usually that math works best for bracket cars. In other words, cars that are built and meant to 60 ft., etc. You know, 4.30 gears, slicks, if automatic 8" converter. Usually have to add .3-4 tenths for street cars.
I agree. I use that math with my own cars to see what "potential" there may be. Stock eliminators usually get on the other side of that math - meaning going faster than that math. If I can get a street tired/highway car to go within 3 tenths of that math, I feel the car is working pretty good.It gives at least a "rough" idea.
I believe the factory FI and OBD1 is his limiting factor here.must be a bad 60 ft. 93 mph should be 14-something. But I agree, I would think the car would run better than that 93 mph.
yes. That kegger intake isn't stellar for performance. I would think still a little better than 93 mph in a A-body with 3.23's and 4 speed though. Still 245 hp "net". More hp and torque than a factory 340.I believe the factory FI and OBD1 is his limiting factor here.
2.56 60 ft says it all. That is terrible for your combo. I see major traction issue. With the right traction, you'd cut 1.8's. Just that alone and you are well into 14's.This was only my second time bringing anything to the track an first time in 30 years, so I am sure driver was a factor. 60' 2.56, 1/8 10.27
