stock ride height
737jetdr
Martinsville, In.
Does anyone know what the stock ride height on an A body is suppose to be and where is it measured from?
It varies year to year, I could post a scaned page but worried about infringment or site policies. If administrator says ok I will. Or just PM your e-add, and I`ll shoot it to ya.
That would be great info! Hope you can post it! Thanks in advance!
Front; measure to level floor, lower ball joint, lower control arm at torsion bar- 1 7/8" difference. From slack, 4 complete turns on torsion bar screw.
That will get it close.
The factory procedure is difficult to measure so I set about 1" between the LCA bumper and the frame rail. Then make sure both sides are equal by measuring from the frame rail to a fixed part of the LCA.
