Stock Spacer Issue
805moparkid
Slant and AFX Guy
Anthem AZ
so i rebuilt the carb, had some issues, and am now getting close to getting it happy again. first i had something stuck in the PV circuit, and cleaned it out, then the float was to high and over flowing into the boosters, adjusted that.
still isn't running right, looking for something and i found it... when i installed a new fiber spacer it is not compressing enough to seal, i can shin a light around the base and see light on the inside of the throat. i had a thermostat gasket which was actually close so i tried to use it as it was soft and no luck.
and idea's on WTF to do?
Put some blue glue on it.
