I liked it. I didn't think the cost analysis (sp?) was spot on. Actually, thought it was way off.
The cost of turning your crank, bearings, and hanging your slugs on the rods is a lot cheaper than a rotating assembly even if you have to purchase new rods.
My 360 (Just did it.) was a $1500 short block. It included a hone and cam bearings.
(Yea, OK, I got lazy...)
No, you have it reversed. The 360 hangs on to the high rpm hp longer than the stroker does. But is down on hp until that level at approximately 5800 where the stroker falls off and the stock stroke carries on longer. Short stroke engines tend to do this. Hold high hp levels longer....am i reading that correctly?
Does the 360 outperform the 410 in both HP and Torque above 6000 rpm?
$1500 worth of stroker parts didn't really buy that much.....8hp & 31tq
Jeff
With the 360, you'd need more gear and converter to match the stroker on the street or track.
360 with 3.91 and 410 with 3.54 would be a pretty decent match.
Had a 408 with some work to E heads and a voodoo 268 make 475hp and 500tq
Stock ede heads choke the crap out of any SB wanting to make some steam. Would have run harder with a set of 2.02 indy x heads. Probably closer to 475+ hp and 500tq
Remember how often your at 6k plus rpm on the street too, that 408 would be way more drivable, and as mentioned, if it had more head on it, it could really make more top end HP also
All the time! 3 times on the way to work. (6 miles) Several times before lunch on Saturday.6000 rpm on the street?
...good point!
Pretty much every time I drive it I do at least a couple WOT pulls!All the time! 3 times on the way to work. (6 miles) Several times before lunch on Saturday.
On one hand Jeff, I see your point. I think the value is in the lower to mid RPM area. That, will be very noticeable while driving.$1500 worth of stroker parts didn't really buy that much.....8hp & 31tq
Jeff
6 miles to work? Damn, I'd be able to run a 5:13 gear too!All the time! 3 times on the way to work. (6 miles) Several times before lunch on Saturday.
