Bulldozer
free ice cream sandwiches
Ok so why in the hell would someone hit the "disagree" button in post # 14 ? Do they know what really happened ???? Hmmm
Shouldn't the warning shots go in # 1 & #2 round... You should fire warnings BEFORE shooting him instead of AFTER...
The whole point is to have four shots heard, but only two slugs found (in the thief's body). Since there's no way to discover the sequence of firing, and you don't want to be firing blanks at a dangerous target, you load them 3 & 4.
I took it as the button pusher took the post as a lie LOLI took it as he dislikes what happened. Instead of disagreeing with what happened.
As long as the first two are placed well enough to stop the target.
Was told that if you had time to fire a warning shot, you life was not in danger. And I would never carry blanks in any firearm used for self defense.
Thanks for the support everyone.
A good friend of my dads gave my three different cables to try out. I'm sure one will work. Buttttt I have to buy tools before I can even think about working on her.
wheres about in MI are you?Thanks for the support everyone.
you might be able to swing by my place and borrow some tools
OuchLong story short the Holley Snipers are on back order until the end of August so I decided to borrow a carb to get me back on the street.
I found three of the four nuts that hold the carb down so I decided it was a good idea to make sure it didn't end up down the intake. Borrowed a bore scope and checked out the intake and all of the runners down to the valves. Wasn't the easiest thing in the world and the edge of the heads where they dump to the valves had a little bit of a blind spot. Pulled the plugs and check cylinders to make sure it wasn't laying on top of a piston. From what I could tell everything checked out.
Got the carb and everything hooked back up and the new throttle cable put on. Cranked her over to see if I could hear anything I may have missed, sounded good so I fired her up. TINK TINK TINK SON OF A *****!!! I missed the nut. The plug didn't look too happy but it was salvageable. The nut is barely recognizable. The nut is barely recognizable. Made it all the way in to the cylinder.
Got the nut out through the spark plug hole. Got her fired up and she ran pretty well with no issues or noises. Going to do a compression check to make sure the valves didn't get damaged though.
