zkx14
Duster De-ruster
I did look into the caster/camber thing a little. Seams there is NO adjustment on a stock Neon. The spindles bolt to the strut with 2 bolts. They can be changed to cammed type to give some adjustment. From what I see mine does not have them. Either way, I don't need to touch those to change the lower control arms/ball joints. So my toe adjustment should be fine for now.Did my Neon alignment. ('toe and go' no C & C) First time I ever did one. Materials required - string, cardboard, butyl rope caulk (window sealer), 2 wrenches and a tape measure. was a PITA with th string flopping in the wind, but I have the steering wheel centered and a little bit of toe in.
