Should have the truck done today. Just fighting me all the way for sure.
Same here only 3am. Kinda dozed for an hour and got up.I woke around 4 the dog had to go out.
Still over at Stan's??Should have the truck done today. Just fighting me all the way for sure.
That's what she says!Talking care of an old dog is a lot of work at times.
No Deans the local mechanic. He is across the street from me. Mopar guy also. Has a 72 Charger and also a GTX in work on a rotisserie right now.Still over at Stan's??
I figured that why you might of just sent that to me.Check the points screw the can come loose in the mail, no lock washers on them. Your new dwell meter will tell that story.
28-32 dwellI figured that why you might of just sent that to me.
And Jimmy being the old MOPAR wrench he is will know what the readings should be.
Get a refund! Bet you can get 10.28 back!So i fired up my power wagon, discovered the fuel pump crapped out. They sure build crap these days. It only lasted 22 years
Is it a custom or still a true flathead??‘32 chevy coming for a tune up next week. From 50 miles away.
Guy isnt happy with his local mechanics.hope its nothing major. Think some guy changed the umbrella valve seals.
Well, after two days, I am able to walk around, and not much back pain...So thats good...Whats every one up to? Think TJ has the best though. Me just want to finish the truck and get it back on the road.
Hot rod. If it goes easy i will charge my hot rod flat rate.Is it a custom or still a true flathead??
