Stop in for a cup of coffee
Good morning. So, plan for tonight is disconnect the fuel line at tank and engine and blow compressed air through...or not. If flows air fine, then the thought is plugging my vent line for the tank, putting fuel feed line in a container and pressurizing the fuel tank ever so slightly to see if blockage us in the tank. So close, but so very far away....
Can you siphon fuel at the hose to fuel pump ?
Have you had the sending unit out? I understand that the sock and the pick up tube itself can cause issues especially after sitting lengthy periods of time.
Going to take the car down to the other garage this morning.
If there's time after speedometer pinion seals, will do the Hoppy headlight alignment on the car.
All I know is the pump does work as it was pulling fuel out of a 1 gallon gas can. I did not have the tank down, should have and may have to yet.
Here the Gem is. Looks better then it is!!!!
Oh yeah duh, I thought it was something else. Cool I went 4 years ago on our move to Tucson from NY.
Like to go with my car that would be cool.
It's 'something else' for sure. :rofl:
The 'reunion' part is a growing group of us that hang out on this thread in particular. Many of us have gotten together at other locations as well. But with the greatest Mopar show on the planet near a bunch of us....Carlisle works out perfect for those farther away.
Will have to check out the load testers and find a nice safe spot to put them too.
Then deal with the stupid heaters the landlord left for me to hang on the wall.
I can see my quick run down to the garage is turning into a morning there...
'load' ? What did Hoppy talk you into dragging home? :rofl:
Had to help help him out!
He still had a VAT CR? tester which will do for a carbon pile/ammeter better than getting a harbor frieght one,
and some other variable load device he said I'd like,
Rheostat that will also do mopar gauges.
