L I B, M R Ducks! O S A R!ICU812 squared?
What's the hold up? Too much Ubering?Well the parts for the guys distributor tester came in yesterday. Now to find time to go do it. Thinking Monday. STILL cleaning up distribs that got wet at Carlisle. Holy cow it is a lot of work down to just 15 or so now! Still have not even went through the cores I picked up, just no time at all.
Actually have had a break. Lots of other stuff needed attention around here. Finally trouble shot the charging issue on the tractor with the short. Was a direct short at least 20 amps. Took a half day but it was the alternator was in a certain position it was draining the battery. Nothing like a intermittent problem to troubleshoot!What's the hold up? Too much Ubering?
Problem was when the other pop up collapsed the water went right into the storage containers with not displayed distribs. Stuff displayed was fine with plastic on it. Lesson learned though particle board and Carlisle don't mix!. Plan on weather stripping them with foam before next year. The small peel and stick stuff should do it.We need to help you come up with a way to batten the hatches on your portable display and inventory.
But the table looks really good. no side walls to block the view.Plastic totes with a false bottom. Snap the lids on for protection.
I used to have one of those shirts lolL I B, M R Ducks! O S A R!
Plastic totes with a false bottom. Snap the lids on for protection. Easy to load up for the trip home too.
The semi clear ones seal well. The interlocking lids not so much.But the table looks really good. no side walls to block the view.
I don't trust those totes in a storm - I think Hoppy had a bunch of stuff in totes this year. OK for a light rain but not a storm.
Plan on making something decent with different levels. Prob some sort of tubing and boards. Definitely need more display room.I hate OSM, particle board - pretty much any sheet goods.
That said.
Reseal the cuts on a outside or marine grade and they should be OK.
Bottoms are good for sitting in water but those tops don't have a chance.View attachment 1715379359 What I have. Hold a lot of weight and are stackable to 5 high.
They just seem to crack. Got a score on those when fastenall closed just have to put some weatherstripping on them. And cover them with plastic also!The semi clear ones seal well. The interlocking lids not so much.
Those would be better! Still collect pools of water on each. PIA when there's a stack of 'em.The semi clear ones seal well. The interlocking lids not so much.
That would be slick!Plan on making something decent with different levels. Prob some sort of tubing and boards. Definitely need more display room.
prob similar but collapsible.
Just have not seen small ones that can support the weight stacked. Each one is around 40-80 pounds depending if they are aluminum or dual points.Those would be better! Still collect pools of water on each. PIA when there's a stack of 'em.
Quiet here.Matt that shoot out in Philly yesterday near you? Wolfie said it was like a war zone there.
