I got sidetracked and thought I had better check out mu pick up. Strange rattling noise from under the hood when started cold. Any guesses?Yep. I meed to sneak over and pull my drivers seat out of the Swinger for a new cover. I have it unbolted but I didn't have anything to remove the seat belts. I might take the 66 out for a cruise if I have time. May be take it to whiskey tasting tonight.
The serp belt was loose enough to buzz. Tensioner was seized. A trip to Oreillys for a $70 tensioner and all is good. I have been having intermittent stalling problems. The internet steered me to a bad connection at the ECM under the hood. Center connector. By golly you can make it sputter by wiggling the harness. Pull the connector apart and make sure all the wires are plugged in all the way. Spray it off to clean and plug it back in. OK so far. Now off to the Swinger.
