Stop in for a cup of coffee
We were supposed to learn swimming in the army. I can swim in other ways, it was not a big problem, but the teacher had it in his.mind to teach everyone this most common way in Norway. So, I had to try. And he was not the kind to give up. And the more he struggled, the more determined he became. Finally I was alone in the pool and everyone was up watching me hoping that at least one of them could figure out what I was doing wrong. The swimming teacher finally gave up... And so did the others too. He did not want to talk about it after that.
Bill
I here ya I can stay afloat on my back but if I turn and try to swim I sink.
Good evening, what a day. Well the stressing part is over, and that is a relief. I am debating if I shall buy another cracked steering wheel and restore. As a spare one.
Bill
Wanna do mine for me haha
Well damage isn’t as bad as I thought, but probably still gonna need both doors replaced and the rear quarter
Better than mine currently that’s for sure lol
And yes, looked very good
Thank you.
I was just looking at them in a better size and the pictures are not very good. I need to take the steering wheel out in the trailer bed tomorrow when the light is good and take new pics. I might post them on my own website, and I can give you the link so you can see them there in full size.
Bill
Got the Bee out and home. It was buried in a storage unit. 5 complete big blocks, 4 bare blocks, 1 long block, 6 rear ends, dozens of intakes, 6 sets of heads, wheels, seats, etc were stack around the car. I took the car and 2 engines. Found complete RamCharger assembly, grill, tail panel, brand new brake lines, brand new fuel lines, and every patch panel needed in the trunk.
Wow! Awesome! Hope the price was decent.
Wife had to buy a suitcase for all the stuff we (she) bought. 21 t-shirts,and a sweater. I got a new pair of sunglasses...
Ya,that’s gotta suck.
Doesent look like they are going that fast, but i bet they are near 100 mph. On water thats fast. Been about 80 mph, thats fast enough.
I saw 2 unlimited Hydros do almost that exact same thing at Mission Bay San Diego. End of the front chute just about to turn into turn 1, big gust of wind under their noses, over they went. :steering:
My best friend wants to see some racing sometime, think he wants to see the drag boats.
It was never common knowledge to Americans, either -- except for a few Americans in the vehicle lighting industry. :)
1940: the first standardised sealed-beam headlamp, a 7-inch round unit, 6 volts, 40/30 watts (high/low), called the 4030.
1950 or so: wattage is increased to 50/40 (high/low) and the new lamp is called the 5040.
1956: aiming pads (three little protrusions in a triangular formation on the front of the perimeter of the lens) and a filament shield (to block stray light that causes backdazzle in bad weather) are added. Wattage stays the same at 50/40. 6v unit still called 5040, new 12v unit called 5400
1958: The reflector focus is improved. Wattage stays the same at 50/40. There is now an effort at a standard system of nomenclature: the first digit indicates the size, the next digit indicates the service application (0 for headlamp), the next digit indicates the revision/version, and the final digit specifies the subtype (high/low beam headlamps, known as "type 2", have a 2 as the final digit; high-beam "type 1" headlamps have a 1).
For whatever reason, the first digit for 7-inch headlamps is "6", while the first digit for the new 5.75-inch headlamp is "4". (the other major market where sealed beam headlamps are used, the British Commonwealth, uses "7" for the first digit of 7" lamps and "5" for the 5.75" lamps). So in the American system, the new 5.75" lamps are 4002 for the 37.5/50w high/low beam (4005 for the heavy-duty version), and 4001 for the 37.5w high beam. The 6v 7-inch unit is now called 6006, and the 12-volt unit is called 6012.
This system of nomenclature breaks down very quickly as the industry seems to make and break rules at random:
1970: the 7" headlamp is upgraded to 60/50w and is now designated 6014. Heavy-duty or long-life versions by various makers are 6015 or 6016. The 5.75" high/low beam headlamp is upgraded to 37.5/60w and is now designated 4000. A heavy-duty, vibration-resistant/long-life version of the 4000 is called the 4040.
1975: the small rectangular (165 × 100mm) four-headlamp system comes along. The 40/60w high/low beam is 4652 and the 50w high beam is 4651 ("46" makes sense because those metric dimensions are more or less 4" × 6", but now we're using the first two digits for the size…)
1977: the big rectangular (200 × 142mm) two-headlamp system comes along. The 65/55w lamp is called 6052 (now we're using "6" for something other than a 7" round lamp, and a random "5" to differentiate from the "1" in 6012, but even though we've got about the same filament wattage as the 6014 lamp, we're using "2" as the final digit…).
1977 or so: GE buys a couple million 60/55w H4 halogen bulb burners (just the glass capsule with filaments inside) from two European makers and begins making halogen sealed beams: H6014 7" round and H6052 200 × 142mm rectangular. Wagner follows suit around 1980, only they call their rectangular unit H6050 (just whatever, pick any digit; they're all good).
1979: US regs change to allow double the high beam intensity. New 5.75" round high beam is a 50w item called 5001. Halogen version is H5001. Halogen small rectangular 50w high beam is H4651.
1984: US auto industry wants lower-wattage headlamps so they can use cheaper switches and wiring. US lighting industry devises a homegrown 35w halogen capsule. Poorer-but-still-legal performance. Now we've got the H6024 (7-inch round halogen 35w high/low beam…except Philips calls theirs H6017), the H5006 (5.75" round 35w high/low beam), the H4656 (small rectangular 35w high/low beam), and the H6054 (large rectangular 35w high/low beam).
1987: Truck-duty extra-long-life halogen sealed beams: H5024 7" round, H5054 large rectangular, H5062 and H5051 small rectangular, and H5501 and H5506 (or H5009) small round—now we've decided the first digit doesn't mean anything and the rest of them are pretty much random.
1992: higher-performance sealed beams with what used to be the standard wattages (65/55 or 60/55 high/low), but we keep the designations adopted for the low-wattage lamps and just add whatever suffix each individual maker likes. GE calls their "High Output" lamps H6024HO, H6054HO, and H4656HO. Sylvania calls theirs H6024XV, H6054XV, and H4656XV. Wagner calls theirs H6024BL, H6054BL, and H4656BL.
So now there's pretty much nothing left resembling any kind of standard numbering system.
Notes:
1. Years are approximate in this longer answer than you probably wanted, and it doesn't go into some of the little-known but really cool sealed beams made in places like Japan, the UK, and the Netherlands.
2. I sometimes wonder what it's like to think of car lights in terms no more complicated than present/absent, works/doesn't, on/off, bright/dim, and white/red/amber.
So, a newer 6024 lamp has only 37.5 watt, both high and low beam, while the quite older 6014 has 60 watt high beam, and 50 watt low beam ? I suspect I need to check my lamps and see if I can see the number on the back side. If it is a 6014 lamp I guess I need to fix the wiring if I will still use the lamps that came with the car.
Bill
Good morning, folks!
I'm piecing together my 400 stroker build and buying all the stuff that's not the block is getting really expensive. $100 here and $100 there grows pretty fast.
I'm thinking I should buy a complete 383 and have it shipped over. Maybe include some speed parts too.
If I move quickly, I'll be able to get all of it in the same container as the block. Needs to be in Chicago pretty soon, though.
I guess I'll post a wanted ad.
Do any of you guys have B block parts laying around? I need most of it except block, crank, rods and pistons. Well, pistons too. The ones I have are dished and I really think I should bump the compression up.
