Sure quiet in here
I didn't go to a party I was supposed to......i stayed home to change u joints.
Pics to follow
Pics to follow
When i put the big block in the 59 dodge, i built all the linkage and brackets. Was an a-body console. 727 of course, but the idea was the same. Its notIt will work but you will need to make a bracket for the down shaft at trans case because the re doesn't have the location ears
Lon
Are you absolutely sure it's not 51 7/16 inches??
Why am I the first to say that?? Do you really think a driveshaft 10 inches shorter would really fit??[QUOTE="Rainy Day Auto, post: 1972795955, member: ]
but 10 inches ..... no way..
First time a woman ever said that!
RE or RH?It will work but you will need to make a bracket for the down shaft at trans case because the re doesn't have the location ears
Lon
Turns out, size does mattet!Why am I the first to say that?? Do you really think a driveshaft 10 inches shorter would really fit??
That's a lot of driveshaft when it looks like 49 might fit right.
Yep!Turns out, size does mattet!
She says measure twice, cut once!Talking nasty while I am being serious about cars would cause you to be out in the dog house and the dog in the house on the couch, so I can talk car to the dog.
Well freaking frack......I should have went out tonight and forgot this car.
I could swear I measured 51 inches
I could swear I did the math and it came it to 51 inches.
The front yoke is bottomed out and the driveshaft is too long.
I was under the impression a 904 is same length as a 3 speed which is also the same as a 4 speed.For a 2nd gen Plymouth A-body:
51 " would be about right for 3 speed manual, or a 904 with a small dif.
from the '68 Plymouth FSM
Manual Transmission 3-speed; 170, 225, 273, 318 C.I. Engines 7 1/4" Axle
51.43"
Automatic Transmission;
170, 225, 273, 318 C.I. Engine 7 1/4" Axle
51.43"
Driveshaft length given from centerline of front yoke bearing bores to
the centerline of the rear bearing bores.
Seems to be correctI was under the impression a 904 is same length as a 3 speed
Same FSM shows the driveshaft with the 4 speed shorter - but it also was only used with the 8 3/4 axle.3 speed which is also the same as a 4 speed.
Probably have to look in a '73 up FSM.I guess the goof up here is that I have an 8.25 rear.
