I was wondering this myself Mitch, do they peek at us from under the wing ??? Seems I have heard of them beforeInquiring minds want to know...Are they Peking Ducks ???.........Or are they Beijing Ducks ???
You Turkey
Supposed to get some snow Saturday. currently saying 6-9”. Temp likely to go a few above freezing. So could be a mix with sleet and rain later. A fun mess - I probably have work.Still snowing. And more on friday.
Dont know, never ran one, but maybe check with Flaming River, they do steering columns......Good morning (8 min left here), still sick but back to work anyway....
Question, is anyone on here running a steering u-joint instead of the factory coupler? If so, what size and spline count for a manual steering box and where did you get it?
Glad you were not hurt, and that you located the issue. That is going to fun to replace...I figured out the brake problem in the SRT. Had to refill the master cylinder first since it was completely empty. Once filled. Had my wife pump the brakes while I inspected under the hood.
One of the lines in the area shown in the red circle has a pin leak and is spraying fluid out on every pump. I must have been leaking fluid the whole time I was driving yesterday until I ran out of fluid and had no brakes at all. Because it is a pin leak, I never felt any brake pressure loss until I was out of fluid. I don’t know why the fluid level sensor didn’t give a low fluid warning but it doesn’t appear to be functioning.
did i miss something?Glad you were not hurt, and that you located the issue. That is going to fun to replace...
Yep......Back read, it is a long post....did i miss something?
I did, didn't see anythingYep......Back read, it is a long post....
im not that blind lolOf course not!
Hello?
Ill do the work and find it for you....Sec...I did, didn't see anything
If its like the old school safety switch, as long as the pressure front and rear was similar enough, it wouldn't shuttle to either contact.I figured out the brake problem in the SRT. Had to refill the master cylinder first since it was completely empty. Once filled. Had my wife pump the brakes while I inspected under the hood.
He can't see what he has blocked.Ill do the work and find it for you....Sec...
I've gotten back to page 12686 didn't see it.Ill do the work and find it for you....Sec...
Ohhhhhh. that makes sense now. duh, i keep forgetting that. Does make the conversations in here harder to follow.He can't see what he has blocked.
Gonna buy you both a cup!
You'll have to front it until I see yous
A brake line in his SRT failed and he lost his brakes, long story short, just avoided a collision...Ohhhhhh. that makes sense now. duh, i keep forgetting that. Does make the conversations in here harder to follow.
I did not have a super like tab, here is latest from paint prison
