HOPPY'S BIDET SERVICE
Have Squirt.
Will Travel.
1-800-WET-HOPP
Have Squirt.
Will Travel.
1-800-WET-HOPP
We have the ONCE beautiful Chesapeake Bay.......We have Lake Michigan...
Tried to pull that here last fall, i graciously bowed out.You know you have a serious tool problem when the “Fancy” Snap on truck shows up at your house! Not the regular truck but the storage box truck!
Those guys are such whores! What did you buy?You know you have a serious tool problem when the “Fancy” Snap on truck shows up at your house! Not the regular truck but the storage box truck!
Time-x. Fast charge or trickle?Well that just sucks! I took the charger off the battery in the 66 and tested it. BAD!!! Only loaded to 150 cca. I tested the battery in the Swinger. BAD!!!! It failed load test at 250 cca. (and it was a green cap repop) Mo Fo now I need 2 batteries. No draw on either systems and inside all winter.
10 amp automatic. It was still charging full tilt this afternoon. The green cap battery in the Swinger is a spiral wound in a reproduction case. I charged it with my smart charger. I might have to see if I can take it apart and replace the battery inside.Time-x. Fast charge or trickle?
Let them cool and charge again. How long did the charger stay on? Some chargers won’t even try to charge a really low battery.10 amp automatic. It was still charging full tilt this afternoon. The green cap battery in the Swinger is a spiral wound in a reproduction case. I charged it with my smart charger. I might have to see if I can take it apart and replace the battery inside.
Overnight @ 10 ampLet them cool and charge again. How long did the charger stay on? Some chargers won’t even try to charge a really low battery.
But did it stay on overnight, or shut off when you walked away?Overnight @ 10 amp
Overnight. It was still charging when I checked it this afternoon.But did it stay on overnight, or shut off when you walked away?
Was the battery warm/hot?Overnight. It was still charging when I checked it this afternoon.
Im not a big fan if the spiral cell batteries. When they get weak there is no recovering.Was the battery warm/hot?
10 amps overnight? Im betting warm. If not, i would suspect charger. (6v setting?)Was the battery warm/hot?
Me neither but that was the only thing available in a Mopar green cap back when I bought that one. My 66 battery is probably 8 or so years old and was a WalMart Never Start to boot. It's a wonder it lasted that long. It had enough power to click the solenoid before I charged it. The same after I charged it. I had 2 different chargers on it. Neither charger made any difference.Im not a big fan if the spiral cell batteries. When they get weak there is no recovering.
Have had regular lead acid batteries that appear bad, but surface charged. A repeated slow discharge and slow recharge will sometimes bring them back. had a commercial 4D battery i got 4 years out of by cycling it.
Hah! I think I put my Snap On guys kid thru college! I followed Franks lead and took a hard pass. They only wanted to give me 12k for trade in on my box. Screw that. They were trying to get me to step up into Epic line. Super nice box’s and 30 inches deep vs 24 but if I am going to have payments on something it is likely going to have a 440 in it! I just can’t wrap my head around payments on a box.Those guys are such whores! What did you buy?
Your buddy probably didn't charge his battery and if he did he probably didn't test it. I did both twice so far. It only carries around 12.5 volts and fails a load test. It will only load to 150 amps. My charger does 12 volts only so on the wrong setting is not an issue.So, 2 weeks ago, buddy says his battery is a pos.
Grab new battery and install it.
I promptly bring old battery into shop and throw a 2 amp charge into it. Next morning, load test.
400 amps and climbing under load, holding 10 volts. Nope,nothing wrong with battery.
Deep discharge. And wont take a fast charge.
Got the idle down to about 1100-1200, bounces between the two.
@Mopar Tim @Mattax @halifaxhops @toolmanmike
Timing is the measurement of the exact moment the spark plug fires expressed in degrees related to a particular piston's location.What is timing?
And that's straight from Captian Obvious!Timing is the measurement of the exact moment the spark plug fires expressed in degrees related to a particular piston's location.
