Found it...thanksGo into your username and click on “my attachments”.
on here? don't know, let me know when you find out though pleaseHow do I go in to see the pictures I have posted over the years?
Go into your username and click on “my attachments”.on here? don't know, let me know when you find out though please
Well have a Great Day All! Gotta get measuring before I hear the neighbors Kubota fire up and start digging holes on my property!
As I remember I believe someone in the site used acetone and shavings from another grill and made a filler/glue type of concoction.Right at freezing up her on the tundra this morning. My grill I purchased off FB made it in yesterday. The seller just put it in a box and marked it fragile, so it is now cracked in the center. I would have at least put a piece of plywood in the box. Holy smokes. But the grill still is a marked improvement over my current one. Technical question to all you plastic savvy folks. What is best glue to use on the crack and do I need to stop drill plastic? The crack is on bottom so I think repair should be graceful. I will post a pix tonight when I get back to shop.
It can be "Welded" Just need heat gun, and the right "rod" Zoro sells the rod....As I remember I believe someone in the site used acetone and shavings from another grill and made a filler/glue type of concoction.
Yeah they work ok, we have a “plastic welder” at work for Argo body repair. The big issue is finding the right rod. And learning how to apply the heat without melting or distorting the adjacent areas.It can be "Welded" Just need heat gun, and the right "rod" Zoro sells the rod....
Lower quarter patches and trunk floor extensions are kind of a turd. You have to open up a big enough hole to get in and work. LOLI need to get them on since the tail panel is back. Chuck the mad santa body man will hang it all for me. Sick of looking at huge cut off areas!
Good morning all. Was in 70's this last weekend, now 50's and talking 29 with snow tonight with windy high of 41 tomorrow. WTF? welcome to spring in WI.
I'm looking at a US General 4 drawer service cart from HF. That's all I need.
well i just blew my car budget for the next 3 weeks, bought me a dana 60 track lok from a member on here. So hopefully by the time it gets here, I can send it to the local guy thats cutting down my D60 and get my axles in. IF and this is a HUGE IF, things go as planned, i could having a running, driving drivetrain in the Dart by August. Body wont be ready of course. But things are finally moving.
not sure what you mean?So dang hard to hide those Danas though
