That's better than cards in the spokes!
Our Bendpak at work only needs air to disengage the locks.Finally got the lift adjusted, not perfectly level or synchronized but after running it quite a bit felt confident enough to put the Duster in the air with it. Question I have for those who have had lifts, is it okay to leave the lift up with the air disconnected. It's sitting on the primary safeties, compressor will run more than I want it to if I leave it connected.
Does your hoist have a air tank on it for reserve? Do you know the minimum air pressure it takes to operate it ?The lift is hydraulic and I believe the primary safeties are mechanical, they latch into the "windows" in the ladders as the lift goes up. When I lower it, if I don't hit the air button to disengage the secondary air locks the lift settles on the primary's (that's where it is now). In order to lower it at this point it has to be raised off of the primary safeties, that's why I'm thinking it might be okay to not have the air on, but not sure.
MarylandMorning Frank missed you in here.
Where does John live?
Your fine without air. It’s only needed to release the locks. What I can’t see though is, is the lift bolted to the floor?The lift is hydraulic and I believe the primary safeties are mechanical, they latch into the "windows" in the ladders as the lift goes up. When I lower it, if I don't hit the air button to disengage the secondary air locks the lift settles on the primary's (that's where it is now). In order to lower it at this point it has to be raised off of the primary safeties, that's why I'm thinking it might be okay to not have the air on, but not sure.
Other side of the state.He can rent Mitches house out then!
i gotcha now. Our safeties are pure mechanical, no air but function the same way. and I've left a 8600 lb Ram 3500 Cummins up on them for nearly a month and they held fine. just make sure they're engaged. If you're nervous, you can always get the jackstands for lifts that are designed as an added safety. They run about 200 a piece.The lift is hydraulic and I believe the primary safeties are mechanical, they latch into the "windows" in the ladders as the lift goes up. When I lower it, if I don't hit the air button to disengage the secondary air locks the lift settles on the primary's (that's where it is now). In order to lower it at this point it has to be raised off of the primary safeties, that's why I'm thinking it might be okay to not have the air on, but not sure.
Must be a 4 post.No, not bolted because I purchased the caster roll around option so I can move it if needed. Really hoping to not bolt it down although if I did I could shim it for level.
That's what I counted in the picMust be a 4 post.
Hmmm. Love Magnums. And always thought they have the look of a big cat ready to pounce. If they had done that black panther positioned better down the sides would have been much cooler. And unfortunately the name Prowler was already taken...
