Stop in for a cup of coffee
Wake up it is TT you know!
Tittie Thursday???
Got up and sprayed the hornets that have started nesting in my Jeep... :elmer:
A couple in a nest on the pillar where the front door mounts...
Then about a dozen of the mother f*ckers in the gas door area that had a nest three tiers high...
Die you son of a bitches, die.... :elmer:
You gotta hit them early in the morning when it's cooler and they are groggy and can't move very well yet... Works perfect to wipe out the whole nest of them... :elmer:
Got up and sprayed the wasps that have started nesting in my Jeep... :elmer:
I just had to call on some wasps that nested under my rear deck steps. I couldn't get at them, they used 2 guys, one spraying from top while other guy crawled way in under the deck. Worth the money to me.
Wasps and hornets aren't my favorite. Bumble bees are more friendly.
I learned a little bit from the pest control guys, we had also asked them to knock down a small hive up under the eves nearby. It ended up being empty. They said that was where they put the queen while they built the nest under the steps, then they moved her in.
Shop vac and a long pipe. Plug hose and leave it in the sun for a day. Works well. Done it a few times.
Sounds good if you can see the nest. I couldn't and didn't want to crawl under to try to do it. I got stung enough last year by mud wasps when I ran a rented "billy goat" brush clearer over a nest down the hill.
Well, gotta scram. Tractor repair guys came out yesterday, spun a new zerk fitting right in my Kubota. Also found another one loose, guess they've seen that before. Also learned I was "back blading" wrong, was dropping my bucket flat to put into float mode. There's a nice thicker edge I should have been pointing down, duh! Will probably get a rattle can of Kubota orange since I was a little tough on the paint there. Have a Great Day All!
