Well if I get home from church and other activities at a decent hour these babies get installed.View attachment 1715601892
You may have to have the bore in the rods redone after installing the new bolts...
Some conn rod bolts use the knurl/shoulder of the bolt to locate the cap on the rod... Changing the bolts can allow the cap to relocate compared to the rod and that misalignment can make a tight crank...
(I said tight crank....)
