Close to the end and add stuff up and OMG!!! How much?????The difference between men and boys is the price of their toys...
Still need: Carb, Pushrods, Torque converter, Linkage adapter, New exhaust, can reuse flowmasters, I bet with this cam can use stock convertor....Close to the end and add stuff up and OMG!!! How much?????
I stopped adding a long time ago, I dont even wanna knowClose to the end and add stuff up and OMG!!! How much?????
The input shaft size. And some of the ones post 71 or 72 were lock up styleSo, what is the difference between older torque converters and newer? Shows 1971transmissions and up only, ?
Hmmmm. How to tell year of trans? I guess I will ask the builder...The input shaft size. And some of the ones post 71 or 72 were lock up style
Get me a number and I'll look it up.Hmmmm. How to tell year of trans? I guess I will ask the builder...
The transmission is at Hoppy's, in PA. I bought it from a builder in Pittsburgh, Wolfie picked it up for me, then took it to Rays........I am messaging Ray now for info....Get me a number and I'll look it up.
That is why the car cannot be completed till at least Carlisle is over, that is when I pickup Trans.The transmission is at Hoppy's, in PA. I bought it from a builder in Pittsburgh, Wolfie picked it up for me, then took it to Rays........I am messaging Ray now for info....
Hmmmm. How to tell year of trans? ...
Good Day Mopar Unibody Abusers'
Numbers that are stamped in the pan rail. I have a book and can look them upHmmmm. How to tell year of trans? I guess I will ask the builder...
It was late 70s at least. If not sooner. I have a 78 727 in my charger that had been swapped in at some point, it was a lock up. Found that out the hard way. That’s how I learned about the pan rail numbers and the input shaftsAnd I'll see when the lock up's started. Mid 80's I believe.
get the vacuum secondary spring kit and put the short yellow spring in the vacuum pod (second lightest) and it will scream....
Mechanical lock up converters in 1978. We were both a few years off. I could mark your post with a red x but I grew out of that in 7th. grade.The input shaft size. And some of the ones post 71 or 72 were lock up style
I just give it to you to mess with the fun policeMechanical lock up converters in 1978. We were both a few years off. I could mark your post with a red x but I grew out of that in 7th. grade.
